2007 Dodge Nitro ignition
2007 DODGE NITRO
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEFINE
the starter fails to disengage after releasing ignition / key switch. I removed the starter/solenoid and it tested ok,solenoid disengaged normally. is a relay the cause or the ignition switch?
Dec 28, 2009 at 8:54 AM
  • 110,244 POSTS
Start with switching the relay with on that has the same part number. If that doesn't work, chances are the ignition switch is the problem.
Let me know what you find.
Nov 8, 2010 at 3:47 AM
