1996 Dodge Neon wont start
NEIGHTDOGG
  • 1996 DODGE NITRO
  • 4 CYL
  • FWD
  • MANUAL
  • 200,000 MILES
Ok I came home for 15 mins turned my car off went in side came back out and all my car would do is turn over nothing else I thought I might of ran out of fuel but I put 5 gallons in it from a gas can and still the same thing im lost it was running fine before that
Saturday, February 28th, 2009 AT 3:03 AM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, February 28th, 2009 AT 3:26 AM
