1995 Dodge Neon Speedometer Bounce
MSCHRIS77
dodge neon, 1995, 122,000 miles manual transmission
i recently purchased a used neon sport and about 2 weeks ago started having problems with the speedometer. prior to this I had to replace the clutch and transmission. after the transmission was replaced the problem with the speedometer started. what happens is while driving the speedometer will start to bounce and when it does that the car seems to feel like it will lose power. it kind of jerks . it mostly does it while on the freeway. it does it a little bit driving in the city but always on the freeway. is there some sort of fuse or sensor that will cause the speedometer to do this and the car to jerk? if so how can i fix it? also the speedometer will sometimes register zero and the mileage will not work either. help!
Mar 6, 2007 at 8:08 PM
  • 75,988 POSTS
VSS vehicle speed sensor-try this for a start
Mar 6, 2007 at 10:17 PM
VAMPYRICO
  • 27 POSTS
the jerking is definately the transmission, make sure you have proper fluid levels. if you have manual tranny, let me know and i will tell you how to check it. the speedometer prob could be a few things. your instrument cluster could be damaged. speed sensor could be bad. if it has a speed cable from the tranny to the cluster, the the cable could be bad. good luck
Mar 9, 2007 at 1:36 PM
JFISCHER
I have a 2000 neon with the same problem, I have found out that the gear in the transmission that meshes with the speed sensor gear was broken, I replaced the gear and the issue was resolved, a month later it broke again($10 gear) + labor which equals removing the transmission and disassembling it to remove the gear.The car was jerky and the speedometer would either not work at all or go to 120 and bounce around until replaced.
Jul 2, 2007 at 7:47 AM
Suggested Repair
Check the vehicle speed sensor, transmission fluid level, instrument cluster, and speedometer cable if equipped. Also inspect the transmission drive gear that meshes with the speed sensor, which can break and cause a bouncing speedometer and jerking.
Conversation Summary
A 1995 Dodge Neon with a manual transmission developed a bouncing speedometer, occasional zero readings, and jerking or power loss after the clutch and transmission were replaced, mainly on the freeway. Replies suggested checking the vehicle speed sensor, fluid level, instrument cluster, and speedometer cable. Another Neon owner reported the same symptoms from a broken transmission gear that meshes with the speed sensor; replacing that gear resolved it until the gear failed again.
