1998 Dodge Neon speedometer not working
1998 DODGE NEON
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
ADAMBRIGHTZ
hi i have a 1998 dodge neon the speedometer is not workingf the gas guage and the heating guage is working fine but no the speedometer.we took the whole dash apart and put new guages in but it still did not fix the problem the same thing happens...we think its goes into the transmission that is causing the problem but were not sure im 17 and i dont kno what to do.....lol im constanly sppeding lol.
but im lost i have tried evertyhing and nothing is working.my dad used to be a mechanic and he cant figure it out either someone please help....im lost
Apr 10, 2008 at 5:06 PM
NEON69
I have a 1999 neon had the same problem. The VSS (vehicle speed sensor) went bad on mine, because of the location of the stupid thing the job took about 1 1/2 hrs. It is located WAY under the car on top of the transmission where the drive shaft for the passenger side comes out. I had to remove a cross brace b4 I could even get to it. Warning when you pull it out the tranny fluid will start coming out so you will need to act fast just be careful you need to get the drive gear off the old one and put it in the new one. It is held on by a couple plastic clips I just broke them off the old one to save time. Good luck.
Apr 26, 2008 at 6:29 AM
