neon problems
KCDAALDRIDGE
just put a new starter on neon. When try to crank it just clicks and there is an apparent liquid that is boiling around the positive terminal. I cleaned all corrosion and tightened down the cable on the terminal same thing still happens also the starter just click extremely hard.
1996 plymouth neon mileage I think is 198000
Jun 4, 2006 at 2:00 AM
KILLZODIAK
  • 13 POSTS
make sure you got the correct starter and hooked it up right. as for the liquid you might want to get a new battery. it sounds like the case is cracked by the positive terminal. I'm not a great mech but i hope that i helped a little. good luck.
Jun 6, 2006 at 4:53 AM
