1998 Dodge Neon 2.0L 125 000 km. I have been having problems with my car overheating. At first I replaced the thermostat before deciding to check the fuse panel. I noticed that the fuse for the radiator/cooling fan was blown. I replaced the fuse and turned the car on again, only to have the fuse promptly blow. I am guessing there is some sort of short in the wiring, or that the ground wire is loose, but electronics aren't really my thing, and Im not sure where the wiring runs to/from. Any thoughts? is this most likely the cause?
May 28, 2007 at 3:56 PM
