My 1999 dodge neon has 85,000 miles
BUSTERCFP
[b:c47fcfb4e8]My 1999 dodge neon has 85,000 miles and the dome light won't go off and the door adjar light stays on yet all the doors are firmly shut how do I fix this because it runs my battery down when the light stays on?
[/b:c47fcfb4e8]
Dec 2, 2006 at 10:31 AM
MARINEMAN9123
  • 7 POSTS
we had the same problem...
just below the door latch (look at the door jam part next to seat) there's a pin switch sticking out... you need to pop it out with like a small screw driver or something and then it should extend it out and when you close the door again voila it should work.
its a self adjusting switch and what happened is you probably had your door slammed too hard or something.
good luck
Jan 11, 2007 at 3:29 PM
