1999 Dodge Neon Belt Half Off Pulley
Suggested Repair
Return the car to the dealer or mechanic and insist the lower belt be correctly seated and aligned on the pulley. A belt riding halfway off can come off and cause major damage. Have pulley alignment, belt routing, and tension checked and corrected.
Conversation Summary
A 1999 Dodge Neon with very high mileage had a lower belt squeak after a leaking radiator hose was replaced. The belt still squeaked and sat only halfway on a pulley. One shop suggested a tensioner; another cited the water pump, timing belt, and pulley as costly problems. A dealer replaced a pulley said to have been bent during an earlier water-pump job and showed parts that had thrown a tooth. The squeak stopped, but the belt still rode halfway on the new pulley. The expert warned that the belt can come off and cause major damage and advised returning so the mechanic corrects the problem.
