I replaced my alternator in my car because I thought my battery wasn't getting it's charge. Now it is like this...the lights go dim and she starts to sputter after driving her for 10 minutes and she shuts off and then the battery is drained. Everyone told me it was my alternator but I replaced it with a re-done one and a new alternator belt. What else could this be taking charge away from my battery?...Please help me
1995 Dodge Neon Battery Drains While Driving
Good luck and let us know. :)
Try posting in the dodge/chrysler forum for more answers.
Thank you very much peppermrj for the help. I went to my friends garage this morning and I got a loan of his voltage tester and put it in the centre of the battery post pos on pos and neg on neg. I had the car started up and it was only reading 11.58 volts. My friend said its the alternator. so he put the tester on the back of the alternator and he said it is gone. I bought the alternator at Auto Parts Network. I would of thought they would test it before they sold it.thank you very much... Please write back Cory Snelgrove..
I advise people either to rebuild, buy new (name brand), or get an American rebuilt unit. I have heard of way to many foriegn rebuilds that don't work right out of the box.
Have them test your new one. Hate installing bad new parts. :twisted:
I am getting tired of putting on parts not working. So last night I ordered a new alternator and the person is ordering it for me is getting it checked firsted because he had the same problem. For me to get an alternator rebuilt down here is $100,00 - $150,00. I am getting a new alternator sent to me for $120,00 plus tax. And I am replacing the alternator my self so that will save a lot. I was to the garage and they told me it would take 4 hrs... I took my alternator out in a half an hour and put one in 20 min.They told me I had to remove the rackapinion or the muffler, but I didn't..but Its not easy changing alternators every day.Thanks for reploying peppermrj
Cory Snelgrove
Don't worry about the lights unless you have to. You would not want to remove them anyway. They are part of the whole package. You want them there to alert you to problems before they get worse and very expensive to repair.
Where you located?
Good luck with the new Alt. Let us know how it goes and if the lights function properly.
Cory Snelgrove 8)
Suggested Repair
Have the battery and alternator tested and inspect the charging wires and connections. A running reading of about 11.58 volts indicates the replacement alternator is not charging. Install a pretested new name-brand or quality rebuilt alternator rather than an untested remanufactured unit. Leave the battery and check-engine lights installed so they can warn of problems.
Conversation Summary
The owner of a 1995 Dodge Neon replaced the alternator and belt after the battery appeared not to charge, but the lights still dimmed, the engine sputtered, and the car shut off after about 10 minutes with a drained battery. A running voltage test showed about 11.58 volts, and testing at the alternator indicated it had failed. The expert advised checking connections, testing the battery and alternator, and using a tested new or quality rebuilt unit. The owner ordered a pretested alternator and was advised not to remove the warning lights.
