gas will not go into tank correctly.
JOEHILESKI
the gas tank is taking less and less gas into the tank with out spilling out or turning off the pump. Even when putting gas in with a can it won't go in with out spilling out.
Jun 23, 2007 at 2:54 AM
WARDIE
have you had any luck with this? I've called many ford dealerships and garages - nobody seems to know how to fix this or what the problem is- it came on all of a sudden and takes about 20 minutes to pump 30-40 gallons of gas- it's as if i'm full all the time which is not the case.
Jul 9, 2007 at 7:47 AM
