Dodge Neon Ignition
MYWILSON
Steering problem
Dodge Neon 4 cyl Wheel Drive Type unknown Automatic 136000 miles
My key will not turn the ignition, what could that be & what should I do?
Feb 21, 2008 at 11:57 PM
BLACKOP555
  • 10,386 POSTS
Try a new key and use some graphite lock lube sprayed in the cylinder and tap it a bit and then that should let the tumblers release and allow it to turn.
the ignition cylinder could be bad also
Feb 22, 2008 at 4:15 AM
