97 Neon Turn signals and stop light.
1997 DODGE NEON
SPOKANE25
97 Dodge Neon with 97,000 on it and auto transmission.
When I turned on the right turn signal it flashed very
fast in the front so changed the rear right stop,turn,tail
light bulb with no luck. Also there in so stop light on the right side but when I turn on the headlight the tail light does work.
Nov 21, 2007 at 6:55 AM
BMRFIXIT
  • 19,053 POSTS
[quote:96feaa6fa7="spokane25"]97 Dodge Neon with 97,000 on it and auto transmission.
light bulb with no luck. Also there in so stop light on the right side but when I turn on the headlight the tail light does work.[/quote:96feaa6fa7]
If the bulb is good and the correct one
You have a broken wire and have to look for it
Make sure u start by checking the socket that the bulb goes in
Good luck
Nov 21, 2007 at 10:19 AM
XERXIES
  • 10 POSTS
hey there did you find the problem, mine is doing the same darn thing...please help...thanks patrick
Dec 12, 2007 at 1:00 PM
BMRFIXIT
  • 19,053 POSTS
[quote:c7e72a3f34="xerxies"]hey there did you find the problem, mine is doing the same darn thing...please help...thanks patrick[/quote:c7e72a3f34]
hi pat
did you check the bulb
Dec 13, 2007 at 2:37 PM
SPOKANE25
I about to replace the turn signal switch on the steering
column, let you know after that.
Dec 20, 2007 at 12:46 PM
