97 dodge neon 2.0l
RFIN123
I have a code 35 coming up(rad fan relay curcuit).I replaced the relay(Dodge parts department said this was a common part to go bad) this didn't help.I was able to find a used pcm, but this didn't help either.I have looked the best I can at the wiring it seems okay.What do you suggest?
Jun 16, 2006 at 12:57 PM
CAPER
is the fan coming on ?
Oct 15, 2006 at 10:17 AM
RFIN123
I found the problem.I wasn't told that this car had been in an accident(the car dealer that I was repairing it for didn't realize it either) .I found a wire that must have been damaged and not repaired.It eventually corroded and broke.I had to open up the harness and trace the wires to find this.
Oct 17, 2006 at 2:30 PM
