2005 Dodge Neon Trying to replace power steering belt tensi
PAT FEE
Engine Mechanical problem
2005 Dodge Neon 4 cyl Front Wheel Drive
anyone have an idea on how to remove the belt tenson pulley.
Nov 20, 2008 at 9:57 AM
MORTICAR
  • 46 POSTS
using the tensioner remove the tension using the hole on the tensioner and a socket wrench. Remove the belt. There should be a bolt in the center of the tensioner not where the pully is but where the spring housing is. Remove the bolt and the tensioner will come off. Hope this helps MORT
Dec 4, 2008 at 1:21 PM
