2005 Dodge Neon Plugs
57,000 MILES • 4 CYL • FWD • AUTOMATIC
BENQUIK
I am using champion double platinum plugs,could they be causing my car to miss fire? I changed the wires and there is no oil on plug 3 code is 0303.
What spark plugs do you recommend?
Aug 30, 2008 at 4:06 AM
BMRFIXIT
  • 19,053 POSTS
possible ignition wire or coil
check for spark on that cylinder
check injector too
switch plugs around if misfire move plug no good
Sep 2, 2008 at 11:40 PM
