Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Neon
Engine
Symptoms
Idle Low
2005 Dodge Neon No Idle
2005 DODGE NEON
55,000 MILES • 4 CYL • 2WD • MANUAL
NEWALLAGUY
MEMBER
1 POST
Car will not idle. Runs fine above idle, but as soon as you push in clutch to stop it drops down to zero. This is an intermittent problem.
Mar 29, 2008 at 10:06 AM
BLACKOP555
Experienced Mechanic
unplug the IAC module and drive it does it still perform the same?
Mar 29, 2008 at 12:12 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
