2005 Dodge Neon missing
74,000 MILES • 4 CYL • FWD • AUTOMATIC
DALE1967DC
I have a 2005 dodge neon sxt that misses at idle when in gear, like at a stop sign or so. It had a code recently about 3 months or so ago for cyl 3 missfire, and I replaced that injector for that cyl and it ran fine. Well it started missing again so I went ahead and replaced the remaining injectors and it still does this. If I power brake it it does not miss and does not miss while driving. Also it doesn't miss real bad sometimes and other times it does. Does it sound like the IAC or so?
Apr 28, 2008 at 1:46 PM
  • 75,988 POSTS
Rescan the computer maybe something new is in there and check the IACV and TPS sensor-also might want to check that cyl.'s compression and plug-
Apr 29, 2008 at 6:49 AM
