2005 Dodge Neon engine light is on
30,000 MILES • 4 CYL • FWD • AUTOMATIC
HDOWNEY42
my engine light is on and when i go to alcerate the car will not go past 30 mph and thr rpms don't go past 2.
Nov 14, 2008 at 6:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like a spark issue. Your vehicle is probably running on only 3 of the 4 cylinders. If you have a code reader, get the codes that the engine light is giving.
More than likely there is an issue with either the coil pack(s), spark plugs, or plug wires. Check to see if any of the plugs are dead.
Nov 14, 2008 at 4:43 PM
