2005 Dodge Neon ECM programing
KSIMMERT
Computer problem
2005 Dodge Neon 4 cyl Two Wheel Drive Automatic
Our car was recently in an accident and the
ECM is damaged. We bought a used one with the exact same part number. The shop put in the codes found in the manual, but still needed more. When the dealership was called they said that you cannot put a used one in. ONLY brand new which are on back order. Have you heard of this before? Thank you
May 3, 2008 at 5:00 AM
BMRFIXIT
  • 19,053 POSTS
used ECM will not work
used or new ECM need to be flashed &reprogrammed
u have to enter VIN and all
for it to work
May 4, 2008 at 9:01 AM
