HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Engine
Symptoms
Revs Up
SPONSORED LINKS
2005 Dodge Neon
JESSICAV.
MEMBER
2005 DODGE NEON
2005 Dodge Neon 4 cyl Automatic 65000 miles
The RPM on my car when idle used to be 1. Now it drops below 1. Is that bad? What do I need to do to fix it?
Friday, January 15th, 2010 AT 4:13 PM
BLACKOP555
MECHANIC
How far bellow one is it dropping? Is it steady when it drops or is it erratic?
SPONSORED LINKS
Friday, January 15th, 2010 AT 6:11 PM
JESSICAV.
MEMBER
It starts at 1 then drops to half.
Friday, January 15th, 2010 AT 7:29 PM
BLACKOP555
MECHANIC
Is the car steady tho at the idle or no?
Sunday, January 17th, 2010 AT 8:50 PM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
2005 Dodge Neon Engine Revs High Then Stalls
Engine Performance Problem 2005 Dodge Neon 4 Cyl Front Wheel Drive 46000 Miles When I Start My Car, It Revs All The Way Up Then...
Asked by
midgetcrazy
1 ANSWER
2005
DODGE NEON
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
Car Revs And Lunges With Foot On Pedal.
First Off, There Is No Check Engine Light On. Twice Today My Car Has Revved And Lunged Forward Slightly. With My Foot On The Brake! The...
Asked by
jessyh200503
1 ANSWER
2005
DODGE NEON
I Received An Error Code Po 700.
The Car Stalls And I Have To Let Up Off The Gas To Correct It. It Also****** If I Reach 3 Rpm.
Asked by
derrickb
1 ANSWER
2005
DODGE NEON
Clutch, Car Revs But Does Not Move
My Car Revs Up But Does Not Go Anywhere It Seems Like It Is In Gear But Does Not Stall Out When Foot Is Off The Clutch. Shifter Also Became...
Asked by
Caliblueyez
2003
DODGE NEON
2004 Dodge Neon Car Reved Up To High
The Car Revs Ups To High When I Turn The Ignition Like It Is Going To Take Off. I Had To Get A New Stirring Wheel Put In Someone Broke The...
Asked by
juliaharnett
1 ANSWER
2004
DODGE NEON
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Vacuum Leak Test and Repair
Online car repair manuals
