2005 Dodge Neon
KEKE04
Engine Performance problem
2005 Dodge Neon 4 cyl Automatic 76000 miles
Last week my battery had corrosion on the connector, but I cleaned it by pouring seltzer water then cleaned it with a steel brush. Today my check engine light came on and when I excelarate it choke like it'll turn off. Any feedback will be great.
Oct 12, 2008 at 12:46 PM
BMRFIXIT
  • 19,053 POSTS
Need to have it scanned for codes
check under hood for any vacuum leaks
check around the pcv valve
scanning and getting the codes will help pin point the troubled area
cycle key on off on read p codes in odometer area
Oct 12, 2008 at 1:03 PM
