transmission fluid in radiator - Coolant inside the transmission?
2004 DODGE NEON
100,000 MILES • 4 CYL • FWD • AUTOMATIC
SGTMAC1
The wife started off to work, got about three miles and the car started hesitating. Trans started slipping and check engine light came on. She drove it at low speed back home where I found the trans to be seriously low on fluid. When adding fluid to the trans, the fluid started running ou of the coolant overflow tank. Taking the radiator cap off showed it to be full of trans fluid. Has the trans leaked into the water jacket of the engine or perhaps the trans cooler has leaked into the radiator? We have noticed no driveline problems with this car since getting it in 2005.
Thanks.
Aug 30, 2010 at 5:56 AM
SATURNTECH9
  • 30,869 POSTS
The only reason is the transmission cooler on the radiator is leaking into the radiator and that's how your getting the transmission fluid into the coolant.I would replace the radiator and flush the cooling system real good and hope for the best. These guides will help fix it step by step.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
and
Aug 30, 2010 at 6:05 AM
DARRINR77
Okay,here’s my question: I have the car listed above SE model. when I first got the car when I stepped on the gas really hard it would slip a little in first gear. as time went on I was driving down the highway and the engine started overheat. I pulled over check the coolant added a little bit and then went to drive away and the transmission would not go into gear. when I finally got it home I checked the radiator fluid and transmission fluid and they both had a thick brown sludge in it. I was wondering what to do about this? I was thinking about flushing the transmission and replacing the radiator and was wondering if that’s necessary?
Feb 24, 2021 at 10:21 AM (Merged)
STEVE W.
  • 15,344 POSTS
Welcome to 2CarPros. Your description sounds like the transmission cooler in the radiator has failed and is leaking. The problem with this is that coolant in the transmission will glaze the friction surfaces in the transmission. The best way to deal with that would be to rebuild the transmission and replace the torque converter as that would get the contaminated fluid out of the entire unit and the friction surfaces will be new. I know of nothing that would flush the coolant out of the friction surfaces well enough to trust them.
You will need to replace the radiator with a new one but, before you do that you will also need to deal with the contaminated coolant and engine. For that you can start by draining the system, blocking off the transmission cooler ports and connect the two transmission lines together to keep from leaking fluids all over. Now fill the radiator with clean water with a bit of classic Dawn dish detergent in it. Run that through it for about 5 minutes, then let it set a bit and run it again. Now drain that out and repeat until the water looks clear. That will clean the oil and crud out of the cooling system and hopefully the heater core. At this point you can drain the system, then replace the radiator and all of the hoses that had the oil/coolant mix in the. The oil and detergents in the transmission fluid will attack the rubber they are made from and they will fail. Better to replace them before that happens. Replace the thermostat as well.
JEFFREYMEIER
Transmission fluid is some how being pumped into the cooling system, how is this happening and where should I start the fluid overflows out of the resovior overflow
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle is equipped with a transmission cooler which shares the same coolant as the engine to help keep the automatic transmission assembly cooled off. There is a fault with the tranny cooler, cooler line or tranny itself causing the tranny fluid to leak into the cooling system.
MERLIN2021
  • 17,250 POSTS
change the radiator the tank is cracked.
JEFFREYMEIER
Where is it located at. I'm used to the line connecting into the radiator itself
MERLIN2021
  • 17,250 POSTS
look at the bottom of radiator the lines should connect there.
MERLIN2021
  • 17,250 POSTS
Here's a diagram...
MERLIN2021
  • 17,250 POSTS
Fluid Condition
Along with fluid level, it is important to check the condition of the fluid. When the fluid smells burned, and is contaminated with metal or friction material particles, a complete transaxle recondition is probably required. Be sure to examine the fluid on the dipstick closely. If there is any doubt about its condition, drain out a sample for a double check. Mopar® ATF+4 (Automatic Transmission Fluid) when new is red in color. The ATF is dyed red so it can be identified from other fluids used in the vehicle such as engine oil or antifreeze. The red color is not permanent and is not an indicator of fluid condition. As the vehicle is driven, the ATF will begin to look darker in color and may eventually become brown. This is normal. ATF+4 also has a unique odor that may change with age. Consequently, odor and color cannot be used to indicate the fluid condition or the need for a fluid change. After the fluid has been checked, seat the dipstick fully to seal out water and dirt. OIL COOLER FLUSHING
NOTE: Manufacturer recommends Cooler Flusher (6906) as the only suitable procedure for flushing oil cooler. Use only petroleum-based flushing solvents. Do not use solvents containing acids, water, gasoline or any other corrosive liquids.
NOTE: Always reverse flush when flushing oil cooler and lines.
Flushing Procedure
1.Note oil cooler supply and return lines. See Fig. 6. Remove cover plate filler plug on cooler flusher. Fill reservoir 1/2 to 3/4 full of fresh flushing solution. 2.Reinstall filler plug. Ensure pump power switch is in OFF position. Connect Red alligator clip to battery positive, and Black alligator clip to chassis ground. Disconnect oil cooler lines at transaxle. 3.Connect Blue pressure line to outlet oil cooler line. Connect Clear return line to inlet oil cooler line. Turn pump on and flush oil cooler and lines for 3 minutes. 4.Monitor pressure reading and Clear return line. Check equipment manufacturers instructions for pressure specifications. If solvent flow is intermittent or exceeds specified pressure, replace oil cooler(s). 5.Turn pump off. Disconnect Clear suction line from reservoir at cover plate. Turn pump on for 30 seconds to purge flushing solution from oil cooler lines. Turn pump off. 6.Place Clear suction line into a one qt. (.95L) container filled with ATF. Turn pump on until all fluid is removed from container. This removes remaining flushing solvent from oil cooler lines. Turn pump off. 7.Disconnect alligator clips from battery and ground. Remove flushing adapters from oil cooler lines. Reconnect oil cooler lines. Fill transaxle with appropriate fluid to proper level. See CHECKING FLUID LEVELS.
Fig. 6: Identifying Transaxle Oil Cooler Lines
Courtesy of DAIMLERCHRYSLER CORPORATION
OIL COOLER FLOW CHECK
1.With transaxle fluid filled to proper level, disconnect oil cooler return line at transaxle. See Fig. 6. Place container under oil cooler return line.
CAUTION:Do not obtain more than one quart of fluid, or transaxle may be damaged.
2.Apply parking brake. Start engine and allow it to idle. Place gearshift lever in Neutral. Check fluid flow from oil cooler return line. 3.If fluid flow is consistent and takes 20 seconds or less to obtain one quart, oil pump volume and oil cooler flow are okay. If fluid flow is intermittent or takes more than 20 seconds to obtain one quart, disconnect oil cooler inlet line. Refill transaxle to proper level and recheck flow. 4.If fluid flow is intermittent or takes more than 20 seconds to obtain one quart, check line pressure. See PERFORMANCE TESTS in appropriate DIAGNOSIS article. If fluid flow is consistent and takes 20 seconds or less to obtain one quart, replace oil cooler. Reconnect oil cooler lines. Fill transaxle with appropriate fluid to proper level. See CHECKING FLUID LEVELS.
CRASSSHETT
My sons car just had a new water pump, new timing belt and tensioners, its been running fine but he goes to drive it today and when it starts shifting out of first gear it sounds like it goes into nuetral. The transmission fluids looks to brown with white in it. The only thing we can come up with is it may have a radiator crack.
Could be the oil cooler for the tranny at the radiator leaking internally.
CRASSSHETT
We looked in the radiator and its got transmission fliud in it.
Replace the radiator the tranny fluid gots no business mixing with coolant-
MDCTLEW
busted coolant line in radiator . radiator replaced . water in transmission . can it be saved ? can it be dried out somehow ? please help .
Feb 24, 2021 at 10:23 AM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
yes it can. i actually got a neon with this problem and fixed it and sold to a friend and its been 2 yrs now. best thiong to do it take it to a transmission shop and have them flush the system. the difference between a flush and just changing the oil and filter is a flush gets all the old fluid out and the filter and gasket only gets out a third of the old oil.
MDCTLEW
hey thanks for your reply about the water in tranny . will the tech need to remove the tranny and pull out the torque convertor and dry it out . then do a flush ?
MASTERTECHTIM
  • 4,750 POSTS
no sir. this is a 1 hundred dollar job
COLBO
I have a 2002 Neon which was put in for servicing at 50,000 miles and the mechanic identified that the transmission fluid was dirty and should be replaced which was done. Now 1,000 miles later the an internal rad coil has develop a leak and the coolant has entered the transmission. The dealer has told us that we now have to replaced the transmission and the rad. We had no indication of problems with the transmission until last minute when fluid was leaking from the car. Is replacement our only option?
Thanks
  • 31,937 POSTS
Hi there,
if this happens, you really have to catch it straight away, because if the trans oil is contaminated with water,it will get in to the valve body and the torque converter and even if you flush the trans you never get rid of all the moisture and corrosion and valve problems will plague you always.
mark (mhpautos)
BLONDIEZ24
My sister bought a 98 dodge neon, with 120,000 miles on it. She need a new transmission for it, so she took it to a transmission shop. They got her one and installed it for 800 dollars. When she got it back she was excited and broght it over and wanted me to drive it. She just turned 16. Well I drove it and it shifted horrible it would rev way high before it shifted, and wouldn't hardly shift into 3rd. Its a 3-speed transmission. I told her something wasn't right to take it back to them. Well she just got her license so she didn't listen to me and drove for 3 more days. I guess it started to shift even worse. It would be in gear going down the highway and start jerking and stuff, then she couldn't even get it to go in gear. She would pull the shifter back to drive and it wouldn't move well after messing with it for a few minutes she got it to move and took it back to the shop. They told her there was water in the transmission. There was no problem with the radiator or anything where water could get in. They have no idea how water got in there. Is this transmission going to be bad now that it was ran with water in it for 4 days? They said there was only about a cup or so of water in there. They think a fluid change will fix it, but I think there will be internal damage what do you guys think?? Thanks
[quote:fe2fde592e="blondiez24"]My sister bought a 98 dodge neon, with 120,000 miles on it. She need a new transmission for it, so she took it to a transmission shop. They got her one and installed it for 800 dollars. When she got it back she was excited and broght it over and wanted me to drive it. She just turned 16. Well I drove it and it shifted horrible it would rev way high before it shifted, and wouldn't hardly shift into 3rd. Its a 3-speed transmission. I told her something wasn't right to take it back to them. Well she just got her license so she didn't listen to me and drove for 3 more days. I guess it started to shift even worse. It would be in gear going down the highway and start jerking and stuff, then she couldn't even get it to go in gear. She would pull the shifter back to drive and it wouldn't move well after messing with it for a few minutes she got it to move and took it back to the shop. They told her there was water in the transmission. There was no problem with the radiator or anything where water could get in. They have no idea how water got in there. Is this transmission going to be bad now that it was ran with water in it for 4 days? They said there was only about a cup or so of water in there. They think a fluid change will fix it, but I think there will be internal damage what do you guys think?? Thanks[/quote:fe2fde592e]
Hey its a new transmission water don't belong in there- Rebuild or New-
I would say the new radiator is leaking into the transmission cooler lines finding its way back to the transmission
