2004 Dodge Neon Stuck in "limp" mode (first gear)
2004 DODGE NEON
104,000 MILES • 4 CYL • FWD • AUTOMATIC
TMCCORD
Hello all,
I am having a problem with my daughters car. 2004 Neon SE 2.0.
The problem: Speedometer jumps around, the check engine light came on, and the Transmission dropped to a lower gear (sounds like first gear) and would not shift out of that gear.
What I did: Found this forum on the google machine, found a possible solution, changed the input and output speed sensors. The car shifted great and ran smooth for about 75 miles and then the problem happened again. I have checked the wires from the sensor plugs I replaced up to the harness (no breaks).
Any other ideas/checks would be appreciated. I am a mechanic for the Army and work on classic cars in my spare time, so I know how to turn a wrench, but the newest car I have ever owned is a 72 Camaro. Electronics, computers and sensors keep me from working at a dealership ;-)
any help will be appreciated. Thanks T
Aug 26, 2010 at 3:14 AM
KHLOW2008
  • 41,814 POSTS
Hi Tmccord,
Thank you for the donation.
If the CEL is still indicating and the speedometer is jumping around, get a free scan done at Autozone and let me know the EXACT trouble code so I can get the necessary information.
Seems the erratic speedometer is the cause of the problem.
Aug 27, 2010 at 5:11 AM
