2004 Dodge Neon My AC isnt workng in my car
2004 DODGE NEON
80,000 MILES • 4 CYL • FWD • AUTOMATIC
WOLFTAILS01
Recently my AC went out in my car. It was blowing cold one minute then it started blowing out hot air. First thing i checked was the ac clutch relay fuse to see if it was bad. It was and I replaced it. After i did that the compressor still wasnt coming on. I took it to a reputable repair person and he told me i had plenty of refrigerant in it. and he ran a test and said there was no leaks. Now he thinks it could be an electrical problem. I ve had this car almost 6 yrs and never had a problem out of it. I've kept it maintained when needed and it still hasnt had a tuneup yet I really dont think its an electrical problem tho. What else could it be that maybe he overlooked
May 26, 2009 at 11:48 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model a RT, SE or SXT? Also I know it is a 4cyl, can you give me the engine size in liter please.
Next, please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that.
May 26, 2009 at 1:28 PM
WOLFTAILS01
My neon is just a regular 4 door sedan, no se or rt or rxt on the back. and i think but im not sure my cycl size is eith 1.6 or 2.0 . I hope that helps some. Also i still havent had it fixed yet. Was hoping to find a solution to the problem.. thanks again for your help.
James
May 26, 2009 at 3:42 PM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the info James but may need a little more.
The manual I am looking at shows it is either an RT, SE or SXT…and you can probably get the engine liter size is you open the hood and look at several of the decals, they usually will tell you the size in liter.
I also use this info to try to narrow down any TSBs that may apply to you.
Does it blow cool while you are driving but when you come to a stop it starts to blow hot?
Also, let’s do a test. With the hood up locate the radiator cooling fans. Turn the AC off. Make sure the car engine is cool. Start the car and see if the cooling fans are on……..are they?
Then reach in and turn the AC on high, blower on too………..did they come on?
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator if you want them checked.
Will wait to hear back from you.
May 27, 2009 at 9:22 AM
IMPALASS
  • 3,112 POSTS
Hello - I haven't heard back from you. Maybe your car is fixed now. I am not sure of your exact model but for the RT model you may have some recalls.. The dealer may fix this for free. Please contact the dealer service department, give them the VIN number of your car and have them check on this to see if it applies to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recall_16.jpg
Jun 2, 2009 at 2:13 PM
