2004 Dodge Neon Engine Light
100,000 MILES • 4 CYL • FWD • AUTOMATIC
31BURNS
The engine light on my 2004 Dodge Neon has been going off and on, but never showing any problems with performance. Then I noticed that when the car is trying to switch gears, that's when a problem occurs. When it has to go over 2 rebs, it gets stuck and I can't drive past 30 mph until the rebs go down. Once I'm over 40 mph, then it can go over 2 rebs without a problem. This doesn't happen everytime I drive, only sometimes...and there's not a consistent pattern as to when it decides to happen. What does this mean?
Jul 27, 2010 at 12:39 AM
  • 75,988 POSTS
Check engine light:
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Jul 27, 2010 at 1:27 AM
