2004 Dodge Neon cant figure out whats wrong
128,000 MILES • 4 CYL • FWD • AUTOMATIC
DREWBALL86
I was driving about 50kms and out of nowhere my engine light turned on and the transmission slipped out of gear. i put it in neutral and coasted for a bit. I made it to a gas station and checked, trans fluid (clean & full), oil (clean & full), coolant is full, and my battery is well charged. I checked for leaks and there were non. I unhooked the battery and let it sit for a bit. hooked it back up and started driving home. the whole time driving the transmission and shifting rough. halfway home the engine light turned on. and where my rpms passed 3000 the gear would slip out until it dropped to 1000 rpms any ideas?
Jul 13, 2008 at 3:57 AM
BMRFIXIT
  • 19,053 POSTS
Check engine light telling u you have a problem to pin point that problem you need to have it scanned for codes
or cycle key on off 3 times read codes in the odometer area
possible causes :
check fuses,
speed sensors
tranny solenoid
wiring
best of luck 2 u
Jul 14, 2008 at 10:32 PM
