2004 Dodge Neon Body Repair
72,000 MILES • 4 CYL • 2WD • AUTOMATIC
STALLION87
I was wondering if you could possible tell me how much it would cost for a front bumper, and my front right door is dented in .... I was in an accident a few years ago I need to get them fixed.
Thanks for your time,
Jojo
Nov 9, 2008 at 1:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Brand new front bumper, primered black only, will run you around $120. This is without the foglight holes and is not for the SRT-4 models.
Brand new side door will run around $200 primered black only.
Labor will vary from location and repair shop. Most of the labor costs will be derived from having to paint the material. Costs will be in excess of $1,500 normally in this situation. You may be better off having the dent pulled if possible. This will save you hundreds alone.
This was just a quick glance at some auto part stores online. You can call aroud your area and maybe save some money. You should also consider calling your local salvage lots as you can find very cheap, used parts that may not even need to be painted if you get lucky.
Hope I helped and thanks for using 2Carpros.com!
Nov 9, 2008 at 1:32 PM
