2004 Dodge Neon BLINKER
766,669 MILES • 4 CYL • 2WD • AUTOMATIC
GIJOE1980
MY RIGHT BLINKER DOES NOT WORK MY LEFT BLINKER DOES WORK. MY LEFT BLINKER SIGNAL ON THE DASHBOARD BLINKS REALLY FAST WHAT IS THE PROBLEM?
Jul 22, 2010 at 10:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely have a faulty bulb on right side of vehicle, check all bulbs front and rear.
Jul 22, 2010 at 12:38 PM
XJESSX8292X
First check to see if a bulb is out and that the wiring is okay going to the bulb.
if you replace the bulb and it still doesnt work it could be the multi function switch.
i have a 1999 neon and i had a brakelight/turn signal out only on one side and i had to replace the multi function switch in my car which was about $160 but it has worked fine ever since.
Aug 7, 2010 at 8:23 AM
