HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Body
Door
Symptoms
Open
2004 Dodge Neon
MHERM
MEMBER
2004 DODGE NEON
4 CYL
2WD
AUTOMATIC
44,000 MILES
How can you make a replacement key that will open the car door and not start the 04 neon start the car?
Monday, February 18th, 2008 AT 9:36 PM
BLACKOP555
MECHANIC
If your vehicle has a coded key you can have a non coded key made, or you can change the tumblers in the door lock's to be different then ignition.
If the keys are identicle keying then you cant make one not start the vehicle unless its uncoded.
Monday, February 18th, 2008 AT 10:33 PM
Please
login
or
register
to post a reply.
Related Door Open Content
2004 Dodge Neon Door Lock
Why Wont My Car Allow Me To Lockbthe Doors From Inside But It Will From The Oitside With My Keys
Asked by
Sjhdz17
1 ANSWER
1 IMAGE
2004
DODGE NEON
Bad Wire Connection Through Doors ?
The Speakers Are Hooked Up Properly The Rear And Tweeters In The Dash Work Fine But Nothing From Door Speakers Could The Connections B...
Asked by
Mblais75
2004
DODGE NEON
2000 Dodge Neon Door Locks
The Door Locks Activate Themselves When The Car Is Running Like If There Was A Door Open, But All The Doors Are Closed And Secure. Also The...
Asked by
k1tana
1 ANSWER
2000
DODGE NEON
I Got My Door Handle Wet And Now My Whole Car Is...
I Spilled A Sticky Drink All Over My Door Handle. I Cleaned It With A Pitcher Of Water. I Must've Gotten Some Water In The Window Buttons....
Asked by
wayjayberry1981
2000
DODGE NEON
2000 Dodge Neon Door Will Not Lock/unlock
I Do Not Have Pwr Locks. When I Put My Key In The Door, It Will Neither Unlock Or Lock. The Key Will Spin Almost Completely Around.
Asked by
ggamer68
1 ANSWER
2000
DODGE NEON
VIEW MORE
Door Panel Removal
Fix a Door That Will Not Close
Door Not Closing
