my car has some weird symptoms. First the lights are going dim to bright repeatedly. It shot off the trouble code p1682 (voltage to low) the other day, with the battery/alternator light coming on. I decided to drive it again to see if it persisted. It did except that code was gone and the battery/alternator light is off. Lights are still fluctuating and I have two new codes p1681 and p0563. I'm totally lost on the p1681, No I/P Cluster CCD/J1850 Messages Received. That one threw me for a loop, I translated to the best of my abilities that it means the Instrument cluster module is receiving no input from the PCM. Will it's working like it always has. Except I am pretty sure my speed sensor is going out becuase sitting at a stop light my engine will rev ever so slightly and the speedometer will hover between 5 and 12 mph. Can you give me any ensight as to what's going on with my car?
May 2, 2008 at 12:00 AM
