2003 Dodge Neon Trouble codes.
106,500 MILES • 4 CYL • FWD • AUTOMATIC
ADFARMER
I know these codes are for transmission issues and low elctrical, but what exactly does that mean and is it something i can fix?
P0562
P0700
Thanks
Apr 9, 2008 at 11:47 AM
BMRFIXIT
  • 19,053 POSTS
I believe code P0562 is battery low volts
1st step check alternator and field ground circuit
check fuses
and code p0700 is a general tranny code you need to scan the TCM for codes
you will come up with new sets of codes identifying the troubled area
good luck
Apr 9, 2008 at 12:28 PM
ADFARMER
[quote:c57a8ab9ef="BMRFIXIT"]I believe code P0562 is battery low volts
check fuses
good luck[/quote:c57a8ab9ef]
Thank you, Sir...
Apr 9, 2008 at 1:32 PM
