2003 Dodge Neon Transmission problem?
65,500 MILES • 4 CYL • FWD • AUTOMATIC
BHOTT44
This morning I was leaving to go to work when my neon started acting strange. I pulled and the car seemed to keep jumping out of gear and then finally when it did stay in gear it would only stay in first and started making a distnict whining noise. What could this be? I did the OBD-II test and it came up as code p0700 which was transmission control system malfunction. What is involved with this?
Mar 9, 2008 at 9:51 PM
BMRFIXIT
  • 19,053 POSTS
You need to have the TCM scanned for codes
p0700 is a trouble in the tranny
but when you scan the TCM it will pin point where .
most common is input out put sensors
good luck
Mar 10, 2008 at 10:50 AM
