2003 Dodge Neon transmission
93,213 MILES • 4 CYL • FWD • AUTOMATIC
CURLYGUY10
when i start my car and shift into drive it will go for about mmm.... 5minutes then feel like its in neutral and wont dirive
Nov 22, 2008 at 12:20 PM
  • 31,937 POSTS
Hi there,
Check the trans oil level and condition, but i would be getting it inspected by a trans specialist and get a test and report done.
mark (mhpautos)
Feb 24, 2021 at 6:18 AM
MORTICAR
  • 46 POSTS
This is caused by the viscosity of the oil getting thinner once its heated. Your transmission sounds worn out and once the oil gets heated it thins out causing it to slip. You most likely need a transmission i would do like mhpautos suggested and take it to a shop to be checked.MORT
