2003 Dodge Neon Trans noise
70,000 MILES • 4 CYL • FWD • AUTOMATIC
CHEVYAVE66
My 03 neon is sometimes making a noise at the rear of the engine / front of the trans. When you can hear the noise the trans will pull. The noise quits the trans quits. No codes!!! What do you think????
May 16, 2008 at 9:59 AM
MASTERTECHTIM
  • 4,750 POSTS
when you say the trans will pull do you mean it will work? and when the noise quits the transmission wont move? get back to us
May 16, 2008 at 11:07 AM
CHEVYAVE66
[quote:2dd7c31268="mastertechtim"]when you say the trans will pull do you mean it will work? and when the noise quits the transmission wont move? get back to us[/quote:2dd7c31268] Yes pull means work and yes the trans will not work when ther is no noise
May 16, 2008 at 11:12 AM
MASTERTECHTIM
  • 4,750 POSTS
either the torque converter is broken from the flywheel or the transmission has suffered internal damage. unfortunately either way the transmission has to come out.
May 16, 2008 at 11:19 AM
