2003 Dodge Neon Steering Wheel shakes at high speed while t
2003 DODGE NEON
57,000 MILES • 4 CYL • 2WD • AUTOMATIC
KASHAN
Hello
I have a 2003 dodge neon. I recently bought this car from a friend. I have been having a problem while going to work. At high speeds ranging from 60-75 mph, when a turn comes and as i make the turn the steering wheel vibrates when returning to its normal position. it vibrates very hard. I have no bent rims nor bad tires. The alignment is slightly out. Could it be my steering wheel pulley? Pump? I have checked the steering wheel fluid also. Any help would be appreciated.
Thank You
Nov 13, 2009 at 11:47 AM
BMRFIXIT
  • 19,053 POSTS
Did you notice if it only happens as you stepping on the brakes as it maybe front brake rotors out of round
Nov 13, 2009 at 11:56 AM
