2003 Dodge Neon s
96,000 MILES • 4 CYL • FWD • AUTOMATIC
NIKKIT22
my transmission only drives in one gear it will not change gear a guy told me that was because a sensor that helps it to change gear is gone out but i am not sure what sensor that will be. so would like to know what sensor would i need in order for my transmission to change gears also my speed- meter doesnt work so i cant even tell how fast im going in that one gear would the sensor stop the speed meter from working also.
Aug 8, 2008 at 10:28 AM
BMRFIXIT
  • 19,053 POSTS
check or scan for codes
it will pin point the trouble
most common speed sensors
key on off 3 times will get u to self diagnose and u can read the codes in the odometer area
Aug 10, 2008 at 2:58 AM
