2003 Dodge Neon Oil Light
ROBERT641
Engine Mechanical problem
2003 Dodge Neon 4 cyl Front Wheel Drive Automatic
MY oil light keeps coming when the car sits idle at a light or is in park unless it's cold then it does not come on until it heats up. Could this be just a sensior?
Nov 18, 2009 at 5:58 AM
SERVICE WRITER
  • 9,123 POSTS
Either the sensor is bad or you have low oil pressure are the two likley reasons. Either check the oil pressure with a separate gauge or try a sending unit (sensor)
Nov 18, 2009 at 7:05 AM
