2003 Dodge Neon engine won't start
167,874 MILES • 4 CYL • FWD • AUTOMATIC
JUAVAS
my 2003 dodge neon just started doing this,it will not start,as if no power is hitting the starter, you move the shifter and the engine starts when you turn the key.
Mar 12, 2009 at 9:09 PM
  • 75,988 POSTS
My problem is I couldn't find some sort of a park and neutral switch that can cause that problem but there's none. The only thing I came up that can cause it, is the ignition switch,starter relay, starter itself to include the computer control of the starter relay.
https://images.2carpros.com/forum/automotive_pictures/12900_no_crank_1.jpg
Mar 12, 2009 at 9:48 PM
