Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Neon
Engine
Mount
Replace/Remove
2003 Dodge Neon Center motor mount replacement
2003 DODGE NEON
62,000 MILES • 4 CYL • FWD • AUTOMATIC
BLUBBER
MEMBER
1 POST
How do you replace the center motor mount on my 2003 Dodge neon 2.0 Ltr Engine code "C"?
Oct 13, 2008 at 7:57 PM
DOCFIXIT
Experienced Mechanic
Need to support engine a floor jack with block of wood on oil pan will do. Take weight off remove mount through bolt then unbolt mount bracket.
Oct 15, 2008 at 3:28 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
