2003 Dodge Neon belt tensioner removal
2003 DODGE NEON
56,000 MILES • 4 CYL • FWD • MANUAL
RSCHROEDER
bad bearing on idler pulley on belt tensioner so i need to remove to replace bearing
Mar 13, 2008 at 2:50 PM
BMRFIXIT
  • 19,053 POSTS
did you buy the bearing
I don’t think you can its a one piece unit
you have to replace it as on unit
good luck
Mar 13, 2008 at 2:54 PM
JUSCOTT22
I just did this recently on a 2000 neon. the way i did it was to jack up the engine enough so that you can take out the bolts for tensioner. it is one big piece. i had to remove the anchor mounts as well. good luck
Mar 27, 2008 at 12:54 PM
