2003 Dodge Neon 03 neon with head gasket blown
2003 DODGE NEON
MAGIC2756
  • 12 POSTS
Engine Mechanical problem
2003 Dodge Neon Front Wheel Drive Automatic 122614 miles
Hello have a 03 neon with head gasket blown got water coming out the tail pipe runing across shop floor and it has lots of compression in the radiator.
I remeber awhile back they had a problem with the head gasket .
Neighbor that work at chrysler dealer ship and the REP told them to take the intake off and remove the head bolt raise the head up slip the head gasket out take some ether spray the block of and slip the new head gasket in . can you still do this on the 03 neon ?
May 26, 2010 at 2:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
a lot more than just removing intake to replace the head gasket on the 03..
May 26, 2010 at 2:40 PM
