2002 Dodge Neon transmission problem
130,000 MILES • 4 CYL • FWD • AUTOMATIC
EUTEN
there is tranmission oil leak from somewhere near the transmission and when it's cold sometimes the transmission have delay when operating. Once drive for 2~3minutes and warm up the car it's OK.
What possible problems does it have?
And what should I do?
And final question.
Most of the dodge cars should use ATF-4 oil for transmission but the former owner had been used regular DEXRON product. Is it OK using it or do I have to change whole oil to ATF-4 product?
Jan 18, 2010 at 7:56 AM
BMRFIXIT
  • 19,053 POSTS
Dexron its not for the Chry product
system have to be flushed and fluid need to be replaced
Jan 18, 2010 at 10:50 AM
  • 31,937 POSTS
Hi there, i agree with the advice from BMRFIXIT, i would only add that Mitchell 1 call for ATF Plus type 9602 oil, is the oil leak you have seen engine or transmission oil?
Mark (mhpautos)
Jan 18, 2010 at 10:56 AM
