2002 Dodge Neon Timing belt
142,000 MILES • 4 CYL • FWD • MANUAL
79KATHY25
I have replaced my timing belt, but the check engine light keeps coming on saying a tooth or two off on the belt. When notches are aligned it willnot turn over to start, What issue am i having is it the mechanical tension that needs to be replaced as well?
Oct 8, 2009 at 3:42 AM
DOCFIXIT
  • 18,828 POSTS
Put belt as to marks then you must enter relearn and cam and crank sensors will realign.
Oct 8, 2009 at 3:50 AM
