2002 Dodge Neon throttle is stuck wide open
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
LIGHTBREAD48
when i start the car it automatically revs up. it sounds like the gas is pressed all the way to the floor.
Jun 20, 2010 at 12:02 PM
  • 75,988 POSTS
Could be the idle air control valve needs cleaning and throttle plate/bore and out of range throttle position sensor/kinked acc cable
Jun 20, 2010 at 12:08 PM
LIGHTBREAD48
i have changed the idle air control valve, the throttle position sensor and the MAP sensor with no luck. still is running at about 9 thousand rpms as soon as the motor starts. i rented a computer and it is giving the codes for the 3 things i have changed already. so i erased the codes and tried again... still giving the code for the MAP sensor.... what should i do? does any body have any idea what might be causing this?
Jun 26, 2010 at 2:38 AM
  • 75,988 POSTS
Check the EGR and PCV valves if its leaking also for vacuum leaks and vacuum at the MAP sensor
Jun 26, 2010 at 6:22 AM
