pan bolt torque ?
SERVICEMSTRG
What is the recommended torque for transmission pan bolts on 2002 dodge Neon automatic transmission?
Feb 21, 2010 at 11:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
14 Ft. Lbs. (19 N.m) Here is a guide that will help show you how to service the transmission as well.
Cheers
Feb 21, 2010 at 11:50 AM
OFFROADGEARHEAD
I managed to strip some of the transmission pan bolts on my 2002 Neon. Des anyone know the Bolt size so I can Buy the correct Helicoils? I think it was 8Mx1.25 on my 97 but I'm not sure. Also does anyone know the Torque Specs?
Oct 27, 2018 at 5:49 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
105 in.lbs
not very much its in inch .lbs
and I also think its a 8X1.25X6mm bolt
BREY08
What size are the transmission pan bolts for a 2001 dodge neon?
FIXITMR
  • 9,989 POSTS
The transmission pan bolts are 12mm or 10mm depending on production date. This guide can help you
Cheers
