2002 Dodge Neon P455
PROFILADY
Engine Mechanical problem
2002 Dodge Neon 4 cyl Automatic 54389 miles
Hi. My engine light came on and it threw the P-455 code.
I checked the gas cap and it makes the noise like "shhh" when I take it off. I cleaned it and the code was still there.
Now I want to check the hoses but I do not know which ones (anyone have a photo?) and I do not know how to tell if a hose is bad. On visual inspection they all look new.
Am I missing anything?
Is it safe to drive like this?
Thanks!
Sep 2, 2008 at 2:18 PM
BMRFIXIT
  • 19,053 POSTS
Its a large leak
so if the cap was not tight code will set
u can have the cap tested and replaced as a 1st step and then reset PCM
special equipment needed to test for leak it a smoke machine
Sep 2, 2008 at 2:54 PM
PROFILADY
Thanks!
Sep 2, 2008 at 2:56 PM
PROFILADY
how do I reset the code ?
Sep 2, 2008 at 2:57 PM
BMRFIXIT
  • 19,053 POSTS
disconnecting battery would reset the PCM
or removing memory fuse
just disconnect the battery negative
for a minute
Sep 2, 2008 at 11:04 PM
