Overheating steam coming out from under the hood
13,800 MILES • 4 CYL • FWD • MANUAL
PKENNEDY
My car overheated yesterday. Steam coming out from under the hood, smelled of burnt coolant. I had to refill with water. I can only go a couple miles and the temperature gauge goes to red and steam is coming out from under the hood. However, it does not leak anywhere, nothing has ever been on the driveway. I did not have the air on and did not notice if the fan kicked on when it got hot.
Sep 24, 2010 at 6:12 AM
  • 110,251 POSTS
Did it overheat at highway speeds or stop and go traffic? Have you ever replaced the thermostat or flushed the cooling system? Also, keep in mind, water will boil at 212 degrees F. The engine's normal operating temperature is around 200.
Here is a guide that can help:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
May 21, 2021 at 8:46 AM
PKENNEDY
Stop and gp traffic. No I have never replaced the thermostat or flushed the coolant.
  • 110,251 POSTS
If it only happens in stop and go traffic, check to make sure the cooling fans are coming on and let me know what you find.
PKENNEDY
A new thermostat and flushing the coolant fixed the problem! No busted head gasket!
  • 110,251 POSTS
That is good. Let us know if you have questions in the future.
