2002 Dodge Neon OBD II Codes
120,000 MILES • 4 CYL • FWD • AUTOMATIC
JM4958
car is driving normal and has no symptoms, but today check engine light came on and gave me P0605 and P0700. Has anyone seen these before or know what its telling me?
Apr 8, 2010 at 1:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
these are transmission trouble codes..
P0605 is fault with Internal Transmission Controller
This means the transmission control module is faulty and needs replaced
P0700 is simply a code to let you know the transmission module has stored a fault code in the computer
Apr 8, 2010 at 2:12 PM
JM4958
I looked up the codes before asking the question. I don't mean to be rude, but I'm looking for some experience or some "what else" causes. Maybe even a "why" or "this is common" with that year or at 120k, "take a look at this buddy" kind of advice.
I understand its calling out a bad tranny controller. I also understand that it could possibly be a connection or wire problem or something that someone before has run into and could offer insight on.
so let me ask this a different way.
This 02 Neon popped a code for the transmission control unit today. Has anyone seen anything that could cause this that is not a bad controller? Anyone have any advise as far as things to eliminate before buying a new expensive part?
PS Car will not shift into 3rd now both driving normally and shifting manually...this just started as soon as i posted the first question.
Apr 8, 2010 at 4:21 PM
JM4958
I hope that doesn't come out the wrong way. You answered my question. I just asked it wrong. I thought anyone would have known to look up the codes first and then go from there.
and...
Just because the PCM thinks something is bad does mean replace it. That is bad advice.
Apr 8, 2010 at 4:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
i already researched your vehicle's TSBs, recalls and common consumer issues....this problem was not listed which is why i gave you the code definitions and the most likely cause of the codes................
Apr 8, 2010 at 4:29 PM
JM4958
Cool. Thanks for the update. I guess it is that bad...
Thanks for your help.
Apr 8, 2010 at 4:48 PM
