2002 Dodge Neon MY TRANSMISSION IS LEAKING FLUID
2002 DODGE NEON
115,000 MILES • 4 CYL • FWD • AUTOMATIC
EDDIE714
I ADDED TRANSMISSION FLUID AND IT JUST LEAKS OUT, ALSO THE VENTS ONLY BLOW COLD AIR.
Dec 13, 2008 at 12:44 AM
MORTICAR
  • 46 POSTS
Did you mean you added radiator coolant? These two items are not related to each other that you posted or are we talking about two seperate problems. give me some more to go on. Location of the leak (front,back,middle,rightside,left side, etc.) colors of the fluid, and how much you have had to add. Let me know and i will see how i can help you.
MORT
Dec 13, 2008 at 5:19 AM
