2002 Dodge Neon HELP
2002 DODGE NEON
94,000 MILES • 4 CYL • FWD • AUTOMATIC
KCREEKMORE
Had a problem with motor mounts about a month ago and had them all replaced. About a week ago I noticed the "shake and wobble" problem. I took it to a local repair shop and they said all was good but it needed alignment and new tires in front. Eventually I would need new struts. I put new tires. I am getting alignment Saturday. It is still doing the same thing. I cannot imagine an alignment problem making it shake from side to side like that....HELP!
Apr 13, 2009 at 6:14 AM
BMRFIXIT
  • 19,053 POSTS
Does the shaking happen in park or only while driving
alignment will not help in shaking
I would suspect a bad tire
was all four tires replaced ?
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 14, 2009 at 11:09 PM
KCREEKMORE
It only happens when I am driving. I just had the front tires replaced. The back ones are relatively new. I am just trying to gear up for a big bill (not that I can afford one in this economy). Can you give me an idea of what might cause this if it is not tires and alignment?
Apr 14, 2009 at 11:58 PM
BMRFIXIT
  • 19,053 POSTS
i would have the rear tires check
Apr 15, 2009 at 2:37 PM
